Hello Chaps,
I'm having a bit of trouble doing some exporting with Compressor.
I have a sequence which is using lots of Magic Bullet editors which is causing ABSURDLY long render times (I read somewhere that compressor re-renders everything... which is causing my problems). The few sites I've checked mentioned to export as quicktimee reference and then to encode in Compressor. Fine. Fair game.
Problem is -- my sequence is in 16:9 and as we all know when you export from FCP to a quicktime reference movie it always exports in 4:3 (for some stupid reason).
In the past I've just changed the frame size to 843x480 as Apple says to do in one techsupport document regarding iDVD + widescreen. The problem with this is that when I went ahead and compressed a file of mine the result was an iPod ready version cropped to 640x304 -- losing a great deal of picture.
So I thought perhaps it was just some strange issue because of the 853. I switched my settings to 720x405... and again the same issue -- its going to export at 640x304. I've gone ahead and just changed the setting myself to the 16:9 aspect ratio so that it SHOULD export at 640x360
I guess my question is - what is the best way around this? Is there an easier way to just do this all in one go? Am I not setting the frame size correctly in QT? Is compressor actually re-rendering all my frames? Can I set it not to?
I really dont want to have to go through this process every time... so if anyone could help that'd be lovely!
:: ehmjay.
Looks like i solved the problem myself.
All I had to do was export the file as QT Reference Movie -- not touch the dimensions, bring it into compressor and it would read it as being actually 16:9 and do it's thing.
So no need to panic.:: ehmjay.
Alternative video filter to Magic Bullet Looks\Colorisma
By kingo'mountain in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2010, 16:14 -
Anyone using Magic Bullet Looks Suite 1.1 to 2.1?
By cooldude859 in forum EditingReplies: 0Last Post: 7th Jan 2010, 04:31 -
Magic Bullet LOOKS doesn't work in 3 different NLE
By beavereater in forum EditingReplies: 7Last Post: 3rd Dec 2009, 11:12 -
Sony Vegas 8.0c (build 260) crashing while rendering, using Magic Bullet
By tranzadikt in forum EditingReplies: 0Last Post: 6th Dec 2008, 15:05 -
Magic Bullet for 50i HDV
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Mar 2008, 05:34
