Hello
I write for a doubt that I have about to selecting input video TV-Tuner
I want to convert VHS video to DVD video...............
My TV-tuner has two input sources:
1) Composite
2) S-video
My VHs player only has out composite video (no s-video)
I connecting "vhs composite OUT" to " video composite tv-tuner IN "
My doubt is:
Would it be better to connect " VHS composite OUT" to " S-video tv-tunner IN"
by means of a "composite to s-video converter wire " ??????
Thanks you for responding
No. In fact, it will probably make the video worse.Originally Posted by goal
The best thing you can do for VHS capture quality is get a S-VHS deck with s-video output, a line TBC, and noise filtering. It will cost you at least a few hundred dollars for a used one. -
Suggest you try the composite to composite connection and determine if the quality is sufficient for your purposes before you go spending a whole lot of money on equipment.
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 21:57 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
SCART to S-Video or Composite converter drops color
By chupacabra in forum Capturing and VCRReplies: 28Last Post: 2nd Nov 2007, 17:32
