Hi to every one here, Ok my question is I want to convert some of my DVD's to a file format for my computer.
1: I want the files depending on the DVD to be between 700mb - 1400mb.
2: I want to get the best quality possible for picture and audio.
3: I'm not to bothered on time to encode or CPU consumption I just want the best results I can get for the file size I specify.
What's the best software and codec to use and how is the best way of going about encoding my DVD's.
Any tutorials for reaching the highest quality would be good, I have check out a few but I'm not to sure whats the best for my needs.
many thanks to any body that maybe able to help.
koy.
I don't know about the 'best way', but ripping with DVDFab HD Decrypter then using AutoGK to convert to Xvid/Divx would be one of the easiest methods. The quality would depend on the settings you use.
According to your criteria, I would use MeGUI and encode to x264, with AAC audio.
This is much harder to learn, and takes longer to do, but the quality will be quite a bit better for that given filesize in terms of both audio & video.
The other drawback is not very many DVD players support x264 playback, so you are stuck with PC playback or HTPC playback (although I bet this will change very soon)
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Convert my dvd's to Avi
By drgt in forum Newbie / General discussionsReplies: 52Last Post: 3rd Dec 2010, 05:28 -
convert DVD to AVI...?
By snadge in forum DVD RippingReplies: 5Last Post: 9th Aug 2009, 21:07 -
Convert DVD to DV AVI
By bgmagic in forum DVD RippingReplies: 14Last Post: 4th Feb 2008, 13:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
