I have a strange capture problem with my new Toshiba laptop running Vista Home Premium. I am trying to capture from a Adstech DVDXpressDX2 box and can only capture 6 minutes 13 seconds of audio. The video will capture fine. I can hear the audio while capturing so I know the audio is working. The problem is when I play back the capture. I have tried upgrading the Realtek audio driver, installed the SP1 Vista upgrade and tried reinstalling the DX2 drivers several times. The DX2 works fine on my older Toshiba laptop (Windows XP) and my Gateway desktop (Vista). The problem is something in my laptop. Any suggestions are welcome. My computer specs are Toshiba Satellite A205-S5812, Intel Dual-Core processor T2330, 2 GBs ram, Realtek High Definition Audio. I'm capturing with the CapWiz software that came with the DX2.
I understand some Realtek audio cards have problems with Vista SP1, but your updated driver should have fixed that. I've got a DX2, but I haven't tried it with any of my Vista computers.
What ever the problem is I had it before any upgrades. I was hoping the Realtek driver update would solve the problem. I would try turning off services or uninstalling programs if I knew where to start. The only other thing I did was run a decrapper program to get rid of some of the crap software that came pre-installed.
I would start by contact Adstech, it could be a known issue.
Google is your Friend -
I have exactly the same problem, but en winxp sp3
you already solved?
mb foxconn 45cms-s chipset 945
Versión de controlador de audio: 5.10.0.5464
Versión de DirectX: DirectX 9.0c
Controladora de audio: HD Audio realtek
Códec de sonido : ALC883 -
I never did get the DX2 working on my new laptop. I think it's a driver problem with the DX2 and the Realtek sound card. I did find a solution for my problem though. I bought the Pinnacle Dazzle DVD Video Creator Platinum, downloaded the Vista driver and everything is fine. Sorry I can't help you get your DX2 working.Originally Posted by tekton364
The problem was solved, apparently was not enabled stereo mix, properties sound card.
Thx.
Glad to hear you solved your problem. I have tried everything I could think of and still can't get it working on my laptop.
Problem No Audio Capture TV Programme With EasyCap DC60
By farid in forum Capturing and VCRReplies: 2Last Post: 26th Apr 2012, 04:14 -
Problem recording audio from screen capture software.
By nick101181 in forum Video Streaming DownloadingReplies: 1Last Post: 12th Sep 2010, 00:40 -
Audio capture problem for a beginner
By jbaugh in forum AudioReplies: 2Last Post: 10th Aug 2009, 08:26 -
Help with VHS -> DVD using capture card (audio problem)
By dustin1 in forum Newbie / General discussionsReplies: 20Last Post: 7th Feb 2008, 23:27 -
Capture Audio Problem!
By thetaco in forum Newbie / General discussionsReplies: 6Last Post: 5th May 2007, 11:26
