in my device manager i get a yellow question mark on thevideo contoller(vga compatible) but i cant get it to work ever since i did a system restore, any advice appreciated
	Did you try uninstalling the driver, rebooting and reinstalling? You might want to download the latest driver from the video card manufacturer first.
	It may be hard to tell without a proper driver installed, but usually in 'Control Panel>Display>Settings>Advanced>Adapter', it will be listed. In Vista, 'Control Panel>Appearance and Personalization>Adjust screen resolution>Advanced', you should see it listed. Probably a ATI or Nvidia chipset. Video drivers can get corrupted easily. If you received system disks with the computer, it likely has a driver on it also.
 And since this is a computer question, moving it to the Computer Forum.
	You could also likely just switch to a generic Windows driver and it will work just fine. Until you know make/model and/or chipset of the video card, you won't know which driver to get.
 Try a program such as SIW (free): http://www.gtopala.com/Google is your Friend
  Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?By Morality124 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Jan 2011, 01:44
  RCA composite video on Wii but component video and VGA inputs on tvBy shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 22:48
  vga output has stopped working and I don't know whyBy xtube in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2010, 03:33
  What video cards support S-Video & Composite output over VGA via adapters?By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 22:57
  Need a video card that will run s-video and vga at the same timeBy fordguy in forum ComputerReplies: 1Last Post: 20th Mar 2008, 14:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
