I'm having an odd problem with the DV files I capture from my camcorder when I try to convert them to Xvid/DivX or any other format with Virtualdub. When the processing by Virtualdub gets near the very end of the capture files I get an error that the audio samples could not be read in the source. This only happens with Virtualdub - not with other programs (Nero, Ulead, etc). I've tried capturing the DV video using both Nero 7 and WinDV in both DV-1 and DV-2 formats, so it appears to be entirely a Virtualdub problem.
Does anyone know how I can fix this problem with Virtualdub? How about a suggestion for another free program that I can use to convert to DivX/Xvid? I would use Nero 7 but it has a bug that keeps me from compressing the audio to MP3.
any help is appreciated.
thanks,
Kevin
Which version of virtualdub ?
I believe the current version can read DV files natively, however the older versions needed a vfw DV codec installed. The Panasonic DV codec and the Cenicida DV codec were the most popular choices.Read my blog here.
I've seen this problem with WMV1 and WMV2 where Virtualdub reports DivX 3.11 audio and refuses to save the last minute or so of the file. To fix this error, I save the audio as uncompressed wave file and either compress to MP3 with Goldwave and reinsert or insert the wave and compress with Virtualdub. It seems to fix the problem.
Not sure the camcorder problem is the same but I'd give it a try. -
I using version 1.7.8, so it should be using the native DV codec to decode the video.
thanks,
kevin -
You can try this version. Phaeron was working on this bug in test 2 and may have it fixed by now.
http://www.virtualdub.org/beta/VirtualDub-1.8.1-test5.zip
If not, try the Cedocida codec until Phaeron can get it worked out.
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 04:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
Audio Source Missing from VirtualDub
By Flynn in forum Capturing and VCRReplies: 3Last Post: 5th Jun 2010, 05:58 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59
