I load a large avi (200MB) with AC3 sound into Soundforge, no problem.
Edit the sound, no problem (enhancements, volume, fad in, etc)
When I try to save it, however, the only options to save the whole file produce a huge 15-20Gb uncompressed file.
Any ideas how to get this done, and preserve the original video (compressed).
VirtualDub can only boost sound, but I wan't able to make it work with AC3. Its audio editing is anyway too limited.
what version of soundforge? pro, studio, 6,7,8,or 9?
which, I guess, involves demux-remux and concerns of losing ac3 multichannel sound as I expressed in another post (and already got some helpful hints thanks to your great members - thanx!)
sf is really just an audio editor. to use it you should first demux and then import just the audio. avidemux should work. sf 9 pro will render ac3 5ch. so when it's done you can remux back with the video.
I just replied with this issue to another thread, but the bottom line is - I got best results with Nero Wavedit which does a great job in decoding and encoding (edited ac3) preserving multichannels and is really simple to use. Used some ac3 plugin in order to accomplish this successfully.
Unless you wish to edit each of 6 channels separately (Nero can do that too, as well as Audition), this is the simplest way to make some basic adjustments to a multichannel or stereo ac3 (boost, fade in/out and other basic and not so basic stuff that Nero can do).
Editing AVI movie with avidemux resulted in distorted sound. What can I do?
By johnharlin in forum EditingReplies: 2Last Post: 29th Jul 2011, 17:49 -
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 23:50 -
Sound track editing
By grandsire02 in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2009, 19:29 -
Copying CD track with Vegas, SoundForge, Nero, ...?
By solarblast in forum AudioReplies: 8Last Post: 29th Aug 2009, 02:21 -
How To Replace Audio with CDAudio on MusicVideos(Soundforge)
By Sartori in forum User guidesReplies: 5Last Post: 19th Jan 2009, 20:41
