Hello Kids.
Under Huffyuv configuration dialog in Vdub one can choose the YUY2 compression method. There are three options, Predict left (fastest), Predict gradient, Predict median (best). I've seen different guides using different settings. Can someone explain to me what the difference (technical) is between the three and which one (opinion) works best for you. BTW, am capturing in 720*480 NTSC. Thank you for your help.
~HgRising
These three choices are just compression options. They do not affect quality, since Huffyuv is a loseless codec (no quality loss from compression).
Predict left is the fastest compression method, uses minimal or little cpu resouces, but results in the biggest filesize of all three compression.
Predict median is the slowest compression method, uses maximum or all cpu resources, but gives you the smallest filesize of all three compression.
Then Predict gradient is a middle of everything.
(Personally I use Predict Gradient)
Hope that cleared it up for you. =]
virtuldub can not open avi file?
By wuqingshi in forum EditingReplies: 6Last Post: 1st Sep 2011, 21:40 -
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 06:38 -
Need help configuring capture configuration
By tomarwater in forum Capturing and VCRReplies: 4Last Post: 9th Feb 2010, 07:11 -
Morgan M-JPEG configuration?
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2009, 04:46 -
Configuration settings Help for Exsate DV Capture
By Logan69 in forum Capturing and VCRReplies: 1Last Post: 25th Oct 2007, 10:57
