I want to convert an AVI file to DVD. These are the steps I follow:
- Add the movie to ffmpegx.
- Select DVD PAL 16:9 (720x576).
- Select 4400 Mb size and push Rate.
- Audio bitrate 192kbps, 48KHz.
My problem is that the result file size is about 3Gb. I loose more than 1Gb that could be used to increase video bitrate and get more quality. Why does it happened? I put 4400Mb in size but the result file is 3000Mb. Any idea to fix this?
Thanks![]()
Movie lenght is 145min and for 4400Mb ffmpegx sets video bitrate at 3998kbit/s, but I don't get a 4400Mb file, only 3Gb.
First, how good does the result actually look? Beyond a certain bitrate, quality does not improve much.
Second, do you select the video bitrate *after* setting the audio bitrate, or before? Set audio rate first, then have ffmpegx select the video rate. It won't make much difference, but depending on what the default is, it can make some difference.
It can also be that your Q values are set such that the quality objectives are met at lower-than-target bitrates. If you don't like the output quality, then try adjusting the Qmin and Qmax values to lower ones. That can increase quality and filesize.
Is their software for playing MP3/Audio files on a 4.3GB DVD in a CD player
By jbitakis in forum AudioReplies: 8Last Post: 26th Jan 2009, 00:04 -
Choosing 'best' size of AVI for DVD?
By terrypin in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 11:42 -
question about how to cut 1 minute out of 4.3GB DVD (no menus)
By jimdagys in forum EditingReplies: 20Last Post: 18th Nov 2007, 01:31 -
1.3GB DVD Help Camcorder
By Mark V in forum MacReplies: 8Last Post: 18th Sep 2007, 11:24 -
Converting AVI to DVD - Only 3Gb
By Mutenroy in forum ffmpegX general discussionReplies: 4Last Post: 2nd Aug 2007, 17:21
