    Mar 2008
    Canada
    Hi,
    I'm using NeroVision Express 3 to make my DVD movies from avi files, but I'm having a really annoying problem. Once the DVD is done, and when I play it, the audio doesn't exactly match the video. The original avi files do not have this problem.
    Is there any way I can fix this? Is there a better program I can use to turn avi files into DVD's??
    Thanks very much for any help
    ferretgrl
    Yep, use something else for downloaded avi files like free tools like dvd flick or favc or try ConvertXtoDVD($50).
    Mar 2008
    Canada
    Thanks for the help Baldrick! I've downloaded dvd flick and I like it a lot - there are no problems with the audio matching the video.
    However, I have these Video_TS and dvd.iso files which are very large - but I'm not sure what I can do with them.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Audio sync issues can sometimes be resolved by simply using a different tool for the conversion.
    ISO files can be opened and burned using your burning application. If you don't have one, try IMGBurn.
    The video_ts folders can also be burned by your burning application. You typically just choose "video mode" and drop the files into the application.
    Google is your Friend
