which is better 23.967 or 29.97? Or does it even matter?
Depends what quality you want it in ie:- movie or tv I think
NUGUN -
Depends if it was a movie or not. I'm converting a movie in pal form right now. I used Virtual dub and saved the audio as a wav. Then I saved the video with the slower framerate (23.976). The movie becomes longer. Use Cooledit to make the wav file the same length, then use TMPGEnc to make your mpeg. I think movies converted to PAL accually run faster so you are just slowing down to normal speed again. If it isn't a movie, i guess 23.976 would work well because it is a closer framerate.
25 PAL to 23.976 NTSC AVI
By Nedward Orton in forum Video ConversionReplies: 8Last Post: 24th Mar 2012, 09:56 -
Convert 29,976 (NTSC) to 25,000 (Pal) AVI
By volker028 in forum Video ConversionReplies: 5Last Post: 23rd Mar 2012, 02:00 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 09:45 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 22:31
