I have DVD compatabile files on hard disk ready for burning. I don't want to re-code them. But i want to add menus and titles How will i do it. Which is the good software for menus and titles creation only.
GUIForDVDAuthor or DVD Styler are free and very capable.
Tmpgenc DVD Author is cheap and easy to use.
Ulead Movie Studio is another option.
After that it starts to get expensive and complex. If this is a one-off exercise, use the free tools. Stay away from things like Nero or Roxio that claim to author - more trouble than they are worth if your material is already compliant.Read my blog here.
If you have DVD compatible MPEG video and audio, then you need to author those files to the DVD format. Look to the upper left on this page for 'WHAT IS' DVD for the DVD format, structure and specifications.
You can use GUI for dvdauthor if you want to try a freeware authoring program. There are other payware authoring programs in our 'Tools' section. One of the simpler ones is TMPGEnc DVD Author.
Another alternative is a all-in-one converter that can encode and author. ConvertXToDVD is a popular payware converter. FAVC, DVD Flick and others are popular freeware converters.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
