Good evening everyone, i'm new to this forum, i came here because I really don't know how to work around this and i guess someone must know how to do it over here
So i extracted this matroska file using MKV EXTRACTGUI, and it extracts 1 avi file, 2 audio tracks and 2 subtitles. Well I really don't understand why, but the subtitles just won't show again after the extract process. Any of you have ever come across something like this before? thanks in advance
Results 1 to 9 of 9
Can you clarify "but the subtitles just won't show again after the extract process?" In the previous sentence you said you successfully extracted 2 subtitles???Originally Posted by Alucardio
Do you mean they just vanished? or do you mean they are renamed? or don't play in a media player?
Sometimes they are .txt files that can just be renamed. -
rename them so they are the same name as the media file, and placed in the same folder. Mkvextractgui will place a name like _track1 at the end sequentially numbered, so just rename them.
eg. "movie.avi"
and "movie.srt"
The video stream might be in a raw format so you might have to re-wrap it into a container for it to play. -
i tried renaming the files already but it didn't workOriginally Posted by poisondeathray
Does the video play, and just no subs?
Did the original .mkv play ok with subs?
I don't use BSplayer, so I'm unsure how it renders subs, but do you have DirectVobSub installed? -
yup, the video plays, the original mkv file played the subtitles just fine, and my bs player have no issues with subtitles.. i even tried using the video file and opening another subtitle just to try out and they worked
I even opened the subtitles with subtitle workshop just to see if there was anything odd, and they seemed perfect to me, i even compared them to another subs and they seem fine, but they just won't show up on the video player :@
Extracting subs from MKV for iPod
By nj473 in forum SubtitleReplies: 4Last Post: 2nd Feb 2010, 13:35 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
Help extracting softsub from a .mkv movie file.
By Danilux in forum Newbie / General discussionsReplies: 2Last Post: 13th Oct 2008, 23:18 -
Issue with Subs after extracting MKV file
By Alucardio in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 22:39 -
Extracting EAC3 from an mkv file
By baconharvester in forum AudioReplies: 2Last Post: 25th Oct 2007, 14:09
