Alright, I downloaded a movie and then downloaded a program for Mac called "Burn" which converted the file over to a DVD file, and then I stuck in the DVD and it said it was burning... it did everything, and then when it was almost done verifying the file contents, it said it had failed because it couldn't verify the file contents..
What went wrong? Is it something I can fix? or do I have to either : find a new burning program, download a different file of the movie, or get different DVD's? I used Sony DVD's with 4.87 GB of space, and the movie was only 2.8 GB.
Help!
some more info: when I ejected the burned DVD and put it in my computer again, it played on the DVD player in my computer, but when I put it in my DVD player that is hooked up to my TV (Hitachi, fairly new, purchased Christmas 2006) it would not work....
It could be that the DVD is in PAL format and your DVD player can't play PAL.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
