  1. Member DuBsTaR's Avatar
    May 2007
    Does anyone know if there is a software that combines different images onto one picture ?
    Similar to this
    Thanks in advance.
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yep...
    this,
    And this.
    :P
  3. Member Conquest10's Avatar
    Chicago, IL
    That's not it. This right here is it
    His name was MackemX
  4. LOL you guys are hilarious
    To the OP: Hotlinking=Bad
    Original source: http://bp3.blogger.com/_cJJ83zflnak/Rk1YjbT3I8I/AAAAAAAAB6A/b3y1Dq9fo0M/s1600/usa_promo_cd_1.jpg
    You can do a simple matrix array in imagegrabber 2 (free), and you have more options in picture merge genius (trialware)
    Cheers
  5. Member DuBsTaR's Avatar
    May 2007
    Cheers
    poisondeathray, thank you for your answer.
