Hello everyone,
I looked around and spent a lot of time reading information. Now is the time to ask...!
I use DGIndex to prepare my d2v file and then open it in GordianKnot to crop it and deinterlace it, and I end up with an AVS file that I convert to avi with vfapi. I then work with that fake avi in vegas.
Now I'm in Vegas 8. I make my color corrections and I'm ready to create the mpg and wmv files I need. But I also need a FLV file for the same video. What I currently do is encode to a very high quality AVI with Vegas, then open it in Adobe Flash Video Encoder to render the needed FLV. I find that the resulting avi is not awesome.
I have found around here that it is impossible to render FLV with Vegas (correct me if I'm wrong). What would be the best way to render my video to a top quality file that I could use in the Adobe Flash Encoder Afterward? Or what is be the best avi encoder I could use in vegas?
Other operation worries:
- In GordianKnot: before saving my AVS, I use Bicubic Soft as Resize Filter and TomsMoComp as Field Operation, is it a good choice?
- Field operation in DGIndex: I'm working with NTSC, should I use Honor Pulldown Flags or Forced Film? I read the DGIndex help file once and concluded that I had to choose Honor Pulldown Flags but in a guide here the author suggested to use Forced Film.
- I find that the stock Sharpen filter in Vegas is crappy, any suggestions?
Thanks for helping.
I just dumped Premiere Pro CS3 (and it's always crashing encoder).
This works nice - rendering from Vegas 8 with MainConcept MPEG-2 then converting that file with MPEG Streamclip (free). Have found this works even better than Adobe Media Encoder (when it actually didn't crash).
Of course you'll have to experiment with settings but you get the idea...
JW
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
format to use for fastest conversion from flv
By cduval04 in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 00:58 -
Export to Flv from Vegas
By Bajazz in forum Video ConversionReplies: 14Last Post: 23rd Sep 2008, 07:39 -
FLV format conversion to MPG4
By Simon5005 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2008, 10:09 -
how to export from fla to flv
By yunakokimama in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2007, 03:15
