I have a NEC DVD_RW ND-3500AG 2.16 and at first it could not burn dual layers, so i upgraded the firmware. I was able to burn one dual layer disk successfully then right after, my computer did not even detect the drive anymore. I restarted and i still could not access the drive. Anyone know what went wrong? Thanks.![]()
Do you by any chance have InCD or other packet-writing soft on that machine? Have you recently changed burning software? Or uninstallled Nero without running the Nero clean tool?
See if this helps:
1) Go to Start -> Run
2) Type in: regedit
3) Navigate to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\
{4D36E965-E325-11CE-BFC1-08002BE10318}
4) In the right-hand pane, if you see Upper Filters and/or Lower Filters, right-click on each and delete them. Do not monkey with anything else.
5) Close regedit and reboot.
That should give you back your optical drive, assuming there were upper and lower filters to delete.
[EDIT] Just noticed there's a similar thread today here:
https://forum.videohelp.com/topic348492.htmlPull! Bang! Darn!
DVD-R to dual layer, blu-ray or hard drive? Possible?
By daysaf00 in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2012, 14:50 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Can my dvd drive burn to dual layer disk?
By HartsVideo in forum DVD & Blu-ray WritersReplies: 7Last Post: 3rd Oct 2010, 15:07 -
Trying to verify my drive can record Dual Layer discs
By wrswldo in forum DVD & Blu-ray WritersReplies: 3Last Post: 8th Feb 2009, 06:14 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00
