  1. Sup guys? hello..i'm a newbie around here and i've got some questions..
    Firstly..i juz got my Final fantasy in DVI format..
    I've visited your section on how to convert DVI into MPg..i did exactly that..but when i try to transfer the file to Nero 5.0 for burning,an error msg appears and it look like this:"The file XXX.mpg is invalid,need mpEg-1 which was encoded for Video-Cd:
    Audio 44.1khz;stero 224kbits
    video 352X240/29.97hz and bla bla bla...
    file analysis audio:
    -Stream Encoding which is invalid for Video CD
    -44.1khz;stero 224kbits"
    what do u guys think is wrong wit this file??
    i did exactly wat was shown in the Convertsion section..i did this like 2 millions times and i also get the same msg..some body help me??
    oh..i live in Singapore...(near the equator) so i guess me VCD and TV are PAl format?
    ThankX a million
  2. i still need help?? can ani one help me?? i successfully Converted the file from .DVI to .MPg..and another problem cropped up...i burnt the File onto a CD-r...kool it works..but when it was played over in a VCD player (Jvc) ...the image and sounds were lagged..it was slow...however..i burnt a MTV along with it and the Image plus Audio was perfect...i'm at a lost...help needed..plz...
    rain13r@yahoo.com
  3. Hi Rain13r,
    I suspect the issue with the error message and the time lag in the audio is somewhere in the conversion. I get that message if I do not use the "proper" templates i.e. my own templates. It would be easier to help if you could indicate how the DV file was converted eg tmpgenc? try using the templates that came with the program.
    With regards to being in Singapore, it doesn't matter if the VCD will be in PAL or NTSC or NTSCFilm. The VCD player and DVD player I have plays all the formats. The TV is also Multisystem, so doesn't matter which format as well. If the TV isn't Multisystem, the VCD player shld be able to convert to PAL internally.
  4. okie...hmm..i used the VCD(Pal) template for the conversion of *.Dvi to MPeg1....i am using Tmpgenc...lag...when i do the conversion..i play half life concurently too..do u think it could be due to this?? i'm using a P3 500 mhz wit 64MB ram...
    options selected/modified when converting to VCD mpg1 format:
    MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps.
    i tried playin the VcD on two different players and as it turns out,one plays a tad bit faster then the other...wat do u think could be the cause of this?? i seriously need help..been wasting like 5 CD-Rs tryin to get the vid to work..damn it..i think i should start gettin CD-RWs....
    Thansks./
