I have a pair of "ts" video files (5Gb total) together with several "PAR" files and "SFK" files in a folder. The video is a "Blu Ray REMUX 1080P VC-1, TrueHD, DD5.1" (Video: VC-1, Audio: TrueHD DD5.1, Aspect Ratio: 2.35:1 16:9 Enhanced, Transfer Format: 1080p HD Widescreen). I was able to play ts files before with Cyberlink PowerDVD, but now when playing this file I can only hear sound but see no video. I tried with VLC player also without success. Any ideas? Thanks.
What version of powerdvd?
Maybe it will work if you use haali media splitter and ac3filter and windows media player 11 or windows media runtime 11 together with mpc. -
I have the latest version of PowerDVD which has alll necessary codecs to play HD, BluRay, etc. I tried with Wndows Media Player11 also, but no success, only audio. I will try your other suggested software. I opened the ts file with Ulead VideoStudio 11 out of curiosity and it reported that the file has no video component, it might be a false positive, I don't know. Thanks.
Of course it is possible that you have bad/corrupt files.
Google is your Friend
I need help playing AC3 audio file with an AVI
By mark85h in forum Newbie / General discussionsReplies: 8Last Post: 18th Feb 2011, 16:04 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:51 -
Playing Downloaded Video File.. Help!
By andrea121 in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2010, 19:44 -
How to stop audio/sound mp3 file from playing when video is finished playin
By lindylex in forum ProgrammingReplies: 3Last Post: 14th Mar 2008, 18:36 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 04:27
