What is Nero smart encoding. Should I use this option . Also tell me should I use PAL or NTSC in my nero vision projects
When enabled, it's supposed to re-encode only if needed and not if it isn't needed. Otherwise Nero will encode anyway at times, needed or not.
Nero's not a great encoder or a burning program, IMO. But if you use Nero, I would enable it and hope it doesn't do any unnecessary re-encoding.
PAL or NTSC? According to my information, Pakistan uses the PAL format. -
Then plz tell which is the good encoder or a burning program that i can use instead of nero
ANd thanks for ur reply. -
Try FAVC for freeware or ConvertXToDVD for payware. They both work well for most formats to a DVD. And they also handle most VBR audio formats and PAL or NTSC conversions. ConvertX is very popular for Xvid or Divx to DVD conversions. For just burning, I would recommend ImgBurn.
Help: AVCHD Canon recordings & smart encoding
By fox86 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 31Last Post: 31st Jul 2012, 09:14 -
Programs for smart encoding?
By spup345 in forum Authoring (DVD)Replies: 3Last Post: 22nd Jan 2010, 14:59 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 10:35 -
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 04:28
