i am using nero vision for dvd Burning. I add files and then in nero preview window the video runs very fast and at the bottom of the window it say NERO SMART ENCODING. but when i go to next window i.e where nero remote contrl is present the video and audio is not sync. Even after burning the DVD im having the same problem PLz help me Why it is happening> And it only happens if i add more than one file in my project. The first files is always ok but the next file has audio video problem
Plz help me
I would try the freeware FAVC or the payware ConvertX to convert your files to DVD. Both perform better than Nerovision most times.
Sync problems can be caused in several different ways. It may be MP3 VBR audio from a Xvid or Divx video. Or a bad framerate conversion, such as NTSC<>PAL, or a corrupted video or audio file, or bad cuts and pastes from editing or joining a two part video.
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 07:59 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 07:53 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
After downmix audio video sync problem
By adarkenigma in forum Video ConversionReplies: 7Last Post: 17th Oct 2007, 09:10 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 04:27
