I have tried using several different programs and methods (including mencoder) to convert WMV to AVI. When viewing the resulting AVI files and comparing side-by-side with the original WMV, I consistantly am getting video with poorer colors than the originals. Is there a way around this?
Poorer in what way? Are the colors shifted or are the color levels lower or higher? Are the black levels and the white levels changed so the video appears darker or lighter?
And what are you viewing them on for the comparison? WMP is not a good choice. Try VLC instead. Since it uses it's own codecs, it leaves out any influence from your installed codecs. -
WebCam program crashed, resulting in a corrupted wmv
By Martificiam in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 04:46 -
WMV to DV (AVI) for ADVC-300 to TV conversion
By rd0591 in forum Video ConversionReplies: 10Last Post: 19th Nov 2010, 05:03 -
AVI to WMV Conversion for Smartphone
By Darklighter in forum Video ConversionReplies: 12Last Post: 29th Apr 2010, 11:56 -
Best app for HD-DVD to mkv conversion? With resulting file size around 4gb
By AndyD in forum Blu-ray RippingReplies: 1Last Post: 7th Apr 2009, 08:46 -
WMV to AVI conversion
By mlimo in forum Video ConversionReplies: 0Last Post: 24th May 2008, 08:55
