I export avi file from premiere pro 2, but it is very very slow to export just 9 minutes video.
If I drop frame rate 24 to 12, would it faster to export? Or should I resize to smaller size when I export?
Perhaps you should consider upgrading your system, or export it overnight when you are sleeping. If your computer details are accurate, a Celeron D and 712 Megs of memory will make things very slow for most video editing tasks
If I upgrade cpu and memory card, would it be faster??? When I play video in premiere pro, it can't play smoothly, stop and play repeatedly..
What kind of cpu and memory card do you recommend?? -
Give us more detail on the video formats you want to export. You should be using a 3MHz or better for DV/DVD formats and Core2Duo for HDV.Originally Posted by yunakokimama
You need an all new computer for Premiere Pro although you can limp along with your Celeron D.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
My computer is built custom. (I bought custom computer from EBAY) so I can replace CPU and video card, memory card and ram.
I want to export AVI video and DVD format video for DVD......... -
What is the speed of your Celeron D? You can upgrade to the fastest CPU your motherboard supports or get a Core2Duo capable motherboard. RAM for XP should be in the 1-2GB range.Originally Posted by yunakokimama
What is your current display card?Recommends: Kiva.org - Loans that change lives.
export to h264 and aac from premiere pro
By codemaster in forum EditingReplies: 1Last Post: 19th Apr 2012, 09:10 -
Final Cut Pro Slow Export
By gooberguy in forum EditingReplies: 1Last Post: 5th Apr 2010, 17:23 -
Premiere Pro Export setting?
By peconi in forum Authoring (Blu-ray)Replies: 12Last Post: 4th Nov 2008, 11:07 -
Premiere Pro CS3 HDV export
By kippard in forum EditingReplies: 0Last Post: 12th Oct 2008, 21:30 -
Premiere Pro CS3 export
By kippard in forum MacReplies: 0Last Post: 11th Oct 2008, 20:33
