hi guys.. i'm having problems converting .avi or .asf files to play on a commercial tv dvd player. After converting the .avi/.asf file into mpeg1, I burn it to vcd format.. then when I tried to play it on the dvd player.. it says "No Disc". Does anyone have any idea how to get it to play on the dvd player?? I'm pretty someone might of post this before.. so.. to save the trouble.. can someone tell me which page its at so i can go there and read about.. thanks.
did you check the dvd player list to see if your player supports cdrs?? and if so what brands... this is probably your problem.
http://www.vcdhelp.com/dvdplayers.php -
Thanks DiViNeLeFT... i think the problem was that i been using CDR and not CDRW... gotta get some CDRW and try again..
thanks again
New to video stuff...
By SiNNiK in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2010, 12:41 -
PXL2000 and other lo-fi stuff
By billythecrashsxcker in forum Newbie / General discussionsReplies: 0Last Post: 28th May 2008, 12:39 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
menus and stuff
By zinc in forum Video ConversionReplies: 4Last Post: 8th Dec 2007, 08:51 -
wanna capture some stuff but i can't.
By spoolintanabe in forum Capturing and VCRReplies: 7Last Post: 10th Jul 2007, 09:54
