I am trying to author a DVD but am having problems with the video
I am using SUPER to convert divx into DVD files for use with GUI for dvdautor.
Recently though, the preset profile for DVD is not working. This forced me to look up the DVD standards and convert it from there. It converted successfully and I succeded in making the DVD.
When I ran it on my player, the frame rate was weird. It seems to pause every few frames (very choppy). I am pretty sure this is a problem of the conversion. The input is 25 fps. It is especially strange because when I put it in my comp and play the files directly, they play correctly. Whenever I used the preset profile, it worked perfectly. I have seen this problem other times and it is not new.
If nobody knows the problem you can suggest a better (free) video converter.
I find FAVC (free) works well, and convertxtodvd (trialware$)
Both author your DVD with simple menus ready to burn, but you can choose no menu and use the VOB output to plug into your own authoring application.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
i need a framerate converter
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2008, 21:44 -
lowering a framerate
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Feb 2008, 11:18 -
framerate switcheroo
By AlecWest in forum Video ConversionReplies: 6Last Post: 15th Oct 2007, 16:31
