    Oct 2005
    U.S.A
    I recently bought dvdfab platinum and it will not update. I can get updates for the free version though.
    The box to check for updates is checked also.
    Any help would be great. Thank you.
    Oct 2005
    U.S.A
    No not yet. was looking for a quick reply here first. You never know if someone had the same problem.
    Thanks for your fast reply.
