Some DVD authoring tools, such as Impression or DVDit or ReelDVD require video and audio as separate streams.
Most accept PCM audio files but these take up a lot of room. PAL DVD players also accept MPEG Layer 2 audio files - much smaller than PCM.
I'm using Ligos MPEG plugin for Adobe Premiere to create the m2v and mpa video/audio files. However the audio file does not contain any CRC error checking. And ReelDVD does require that.
Is there any tool that either can convert/add this CRC information to the mpa file or one that can generate it from a plain PCM file?
Results 1 to 1 of 1
converting mpeg into multi channel audio
By markdueck in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2011, 16:35 -
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 05:47 -
Converting AVI to MPEG-2 with no seperate audio file
By Craig876 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 17:38 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 17:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 15:56
