Hey guys
please, can someone point me an updated guide to convert a dvd9 into one dvdr with maximum quality ?? one with a 6 pass on CCE maybe
thanks a lot
Hi-
DVD-Rebuilder is free and supports CCE for what you want to do. There are lots of guides for the use of DVD-RB:
https://www.videohelp.com/guides?searchtext=&tools=565&madeby=&formatconversionselect=&...or+List+Guides
If you just want a CCE guide, then maybe some of these will do:
https://www.videohelp.com/guides?searchtext=&tools=85&madeby=&formatconversionselect=&h...or+List+Guides -
Read my blog here.
I agree with you on passes, but CCE Basic is only $50 and works well with Rebuilder.Originally Posted by guns1inger
I ended up using CCE with 3 pass.
The video had 5.53gb (2 hours 19 min.) and was compressed to 4.10gb, and you cannot tell the diference between one and another.
I only noticed some diference when open 2 virtualdub windows, one for the original and one for the compressed , put both on the same frame and superpose the windows, only then you can see very few pixels changing places
Thanks a lot everyone
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 1:1 Copy
By Lastman369 in forum DVD RippingReplies: 5Last Post: 12th Jan 2010, 13:48 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
Sticky upate? When will Dual Layer DVDr disk be available
By JoeBolden in forum FeedbackReplies: 1Last Post: 11th Jun 2008, 03:54 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
