My AverMedia PCI 300 capture card and UltraTV software worked fine for years until I installed a Veo web cam. Now UltraTV crashes on startup. It will not uninstall, and it will not reinstall until it is satisfied that every trace of the old installation is gone. Does anyone have a manual way to remove UltraTV? I uninstalled the web cam, but the damage had already been done. Now it's far too late to try system restore. Do I need to sift through the entire registry looking for "ultratv", "avermedia" and "veo"? The installer could also be recognizing some obscure dll files in the Windows directory. Yeah, I also tried a utility that removed the entry from the add/remove programs list, but the installer disk still thinks the program needs to be uninstalled. Yiiiii!!!!
	Hi you could try an uninstaller such as http://www.ursoftware.com/ the trial version is at the bottom of the page, if it won't uninstall use the force uninstall comand
	Thanks for the tip. I tried the uninstaller. It's is a beautiful piece of software, but it could not find UltraTV on my system. In a few days I'm going to swap out the capture card, and put this one away until I have a fresh system to drop it into.
  Help watching tv on Avermedia HD DVR capture cardBy mason dixon in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2011, 12:00
  HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV CardBy Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 01:05
  Problem with a new Avermedia M150-D tv tuner cardBy MidnightMike in forum Capturing and VCRReplies: 0Last Post: 28th Dec 2009, 13:35
  4 port capture card - avermedia lx5004 - not working correctlyBy 4dplane in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2007, 21:39
  PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputsBy SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
