I have a 700MB movie file and Gspot says that the file parameter is Xvid, 1000kbps. I want to experiment with using Virtual DubMod to reduce the file size, for example to 500MB. In Virtual DubMod, I choose Xvid compression, 700kbps and the projected file size is about 500MB. My question is: Will a Xvid, 700kbps video play in a DVD player (that plays Xvid)? Also, if I want to reduce the file size even further, how low can I make the Xvid bit rate and still have it play on a Xvid compatible DVD player?
I think it might depend on the model/specs of the DVD player.
You would be better off using the original source DVD to make your "smaller" XviD file as the 700MB XviD is already compressed. If you don't mind bad quality or blocky video artifacts go as low as you want
You could easily test a small file from virtualdubmod yourself, just use the mark in/ mark out sliders and test a 1 minute clip at a certain bitrate. It would only take few minutes. Then adjust the bitrate and try again.
Cheers -
It should unless you enabled some of the options that some players can't handle. Like GMC and QPEL.Originally Posted by jimdagys
You're more likely to get disgusted with the quality before you find a bitrate too low for your player to handle.Originally Posted by jimdagys -
Also, Xvid will bottom out on bitrate at some point. Depending on the video, somewhere around 200 kbps. Setting the bitrate lower than that bottom point will not make the file any smaller
tv player at reasonable price that can play hi bitrate xvid/avi?
By extent in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2010, 09:42 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25 -
Trying to make a DVD play on windows MEdia Player
By WuTangDvD in forum Software PlayingReplies: 6Last Post: 23rd Oct 2007, 09:24 -
Is this DVD Player can play Divx or XviD?
By php111 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 6th Oct 2007, 08:29
