I use Vegas & DVDa.
Love them both, almost perfect.
Almost: means problems with subtitles.
I can import and make DVDs with subtitles, no problem.
But importing a subtitle file leaves me with a blank line between the upper and bottom line. Seems that DVDa doesn´t like the
flag. I searched the net all over, and the only thing I found: unanswered questions. Maybe you can help me.
If I export the subtitle from DVDa to a textfile, after deleting the empty extra line:
there´s a rectangle (linebreak) symbol in notepad. Copying and replacing
with the rectangle doesn´t work.
I even used a Hexeditor to change it, but now the second textline doesn´t even show up.
Is there any way, to edit the pure textfile, so there will be no empty line between upper textline and bottom textline?
Tried also | - no way. Shows up as a symbol.
I really want to edit, check the subtitle text in Notepad. Easier to overview the whole thing. And it´s a hazzle to edit the subtitles in DVDa.
Btw: why can I save the subtitles in DVDa in a Vegas region list format? I can´t find any way to import a region list to Vegas (export no prob).
Long, large post. Have patience - thanks
Results 1 to 10 of 10
Hi NoBuddy,
Had the same problem untill I fixed it this way:
1) Open the SUB-file in Word 2003
2) Save as Plain text (including the extention .SUB, not TXT!)
3) In the following dialogue box choose Unicode
4) under options choose 'only CR' for linebreaks
Do not use any styletags, styles can only be modified within DVDa.
Hope this'll solve your problem... -
Lippy Lipstick:
Big thanks ! Yes, that did it !
Now I can edit Subs in Words, and they show up as supposed to.
Problem solved - thanks to the high flying dutch man LL - Bedankt. -
Congratulations! I know how frustrating it is
to see things happen you don't want to happen...
Happy subtitling, NoBuddy!
LL from the Lowlands -
Just tried out Subtitle Workshop 4 Beta 2.
Where you can save the file directly as DVD Architect subtitle script (sub)
But even this makes an extra line.
So the trick posted by Lippy Lipstick is still necessary. -
Saving subtitles in order to import in DVDA, has been implemented in old versions of Subtitle Workshop for a long time. That was Sonic DVD Creator format.
DVDA up to version 2 did not show that third "empty" line between 2 sub lines.
That occured starting from DVDA version 3. But if you import all your media files and subtitles into project, then format 1 subtitle line as you wish it to appear, then apply formatting to all subtitles, save it and exit DVDA - next time you open that project, the subtitle will appear right as it should be. -
Hi , i have another question related to this theme. I already got the process of aplying subtitles in DVDA and it works ok. Now I need to incorpor the subtitles i created for DVDA into a Vegas project. In DVDA i found the option "Export Subtitle" in a "Vegas video Region list" that makes a txt document with all the data. How I Import this file into the Vegas timeline (if its possible to do it ), because i havent found the answer anywhere,
please help!! -
Originally Posted by Init
[/img]
I must have found it somewhere then. Anyway, I uploaded the script file plus a few other useful ones at Wikifortio.com, from where you can dl it using the file id 141804.
hope that helps you. The dl will be available for 89 days from today.
regards,
init
SOLVED: preview, out of sync subtitles behind Subtitle Workshop....
By bahjan in forum SubtitleReplies: 0Last Post: 10th Mar 2012, 05:27 -
Spanish subtitle characters in Sony DVD Architect
By Lastman369 in forum Authoring (DVD)Replies: 0Last Post: 13th Apr 2010, 19:42 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
Subtitle background is not transparent *solved*
By Meriks in forum SubtitleReplies: 3Last Post: 9th Feb 2008, 15:47
