Can I get y our opinion of Aspect HD for an HDV project?
Top of the food chain for lossless editing codecs. Really, really fast. Do the features satisfy all of your requirements?
http://www.cineform.com/products/Aspect-Prospect.htm#10bit -
For which editor? Aspect HD costs $499 and is overkill for HDV.
- Vegas 6/7/8 ships with a basic Video for Windows Cineform codec that works fine.
- Neo HDV works with most editors and costs $249 list. Advantage is direct capture to Cineform and a more efficient (space/time/quality) version of the codec.
http://www.cineform.com/index.aspRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks guys. edDV suggested NEO HDV in our previous thread and I discovered I have access to Aspect HD. So, clearly, I should use that? Overkill? Opinions on what to shoot (i.e. 50i, CF24 etc. with a Z1U) and feed to Aspect for the best film look are appreciated. (Yes, I'm still flogging that topic.)
Film look has to do with 1) Lighting 2) Depth of Field 3) Frame Rate 4) Color Grading and visual look of the film - grain. -
I just want someone to tell me exactly how to shoot it, but, clearly I have to decide for myself. But go ahead and use Aspect HD, right?Originally Posted by Soopafresh
If you have access to Aspect HD use it but if you are buying new, Neo HDV is all you need.Originally Posted by kippardRecommends: Kiva.org - Loans that change lives.
Premiere CS3 export to HDV - problem with aspect ratio
By perplexityincarnate in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 1st Apr 2010, 10:12 -
Mixing different aspect ratios on the same Project
By MarioB in forum EditingReplies: 1Last Post: 6th Jul 2009, 06:40 -
HDV project final export
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 15th Oct 2008, 04:02 -
Inclusion of DV footage into HDV format project
By adanchev in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 01:34 -
what pixel aspect ratio to use when making mpeg titile for DVD project
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2007, 04:49
