I get an error trying to import quicktime movies into Sony Vegas. I have Quicktime Pro, so what I do is make the file export to Quicktime Movie and then I re-import it again. I was wondering if anyone knows why I would get an error with importing a quicktime movie and if so, how to fix it?
Results 1 to 9 of 9
So it works to import in vegas after you use quicktime pro and save as a new mov?
What video and audio codec in the mov? Because a mov can contain different video and audio codecs and vegas may not support everything. -
Okay, here are the codecs for all of the videos: MPEG 4 Video and u-law 2:1 for the audio codec
Well, instead of taking the time to export the video I just resave it with a different name and then it imports just fine.
Hi. I have a Kodak PlaySport that exports files into .MOV, and they open in Sony Vegas(Pro 9), but it only shows like 2 frames per second.
I tried converting it into an .MPG file, and then it works, although the videos are HD, and when they open with the new file format, the quality sucks dinosaur nuggets :\
Help? -
I have a PlaySport and Vegas Pro 10. The files open as Sony AVC/AAC. Very standard format, no weird codecs. I think the "two frames per second" experience is the lag in the preview window because your computer is too slow for H.264, so it skips frames.
Try switching the preview to half size.Last edited by budwzr; 9th Feb 2011 at 23:09.
Problems importing MP4/AVC video in Sony Vegas Pro 9
By mltwitz in forum Video ConversionReplies: 1Last Post: 30th Oct 2011, 13:57 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Importing an MPEG-4 to sony vegas platinum 9
By txpredator in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2010, 19:25 -
Problem with Sony Vegas importing DVDs
By aporreca in forum EditingReplies: 2Last Post: 31st May 2010, 09:28 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00
