    Aug 2006
    Has anyone else had trouble rendering their movies in Maya 8.0? I tried to render a 176-frame animation at least eight times tonight, and it always crashed on a random frame, always when it was 96% done.
    I've always tried to render it into a Quicktime file, with h.264 at best quality.
    When I removed the Alpha Channel, it completed fine, but the animation didn't show up in the .mov file; just black.
    Has anyone had a problem like this? How can I fix it? I only have six weeks to get this cartoon finished, and I've barely started. Thanks.
    Apr 2004
    Miskatonic U
    Just a tip, from someone who has been doing 3D for more years than I care to remember, render to still frames and build your video later. It means you don't have to re-render as many frames if something glitches, and it is easier to go back and make subtle changes if necessary. Use tif or tga if you need alpha channel support.
    Read my blog here.
    Aug 2006
    I did try rendering it as a series of .tif files, but something else happened; the files were out of order when I imported the series to After Effects. I repeated it three times with different file names, but got the same result... and it kept crashing while rendering those, too, also at 96% each time.
