    Nov 2003
    I'm basically doing what this guy was doing:
    https://forum.videohelp.com/topic284148.html
    Well actually I'm doing exactly that. I copy and pasted the command and everything. And it's converting fine, except it skips a frame right at the beginning and then the picture gets screwed up until it hits another keyframe.
    At the bottom he said he used "-skipframe 0" to get it to stop skipping frames, but doing that, or "-noskip", didn't seem to change anything.
    I can post a log if needed but it looks a lot like the guy's log, except it's only skipping a frame at the beginning.
    (I realize that post is two and a half years old but it was nearly working so I went with it. If there's a better way of doing the same thing (batch ac3 to mp3), that works too.)
  2. Member Soopafresh's Avatar
    Jan 2004
    Try the Avi_Gain_Regular.bat file in this thread:
    https://forum.videohelp.com/topic314909.html
    Nov 2003
    That seems to work. Thank you.
