I am trying to remove an overdub of french naration over
an english speaking person.
I have tried virtual dub for mpeg2 files and it seems to work ok but it doesnt show
the audio track, only the video.
I am using win xp home.
Tried win movie maker,. . . useless.
Cheers
Most likely, the 2 voices are overlaid on the same audio track (if you hear both simultaneously that's a fact) and there's nothing you can do about it, except find the audio without the French dub, and replace the audio.
/Mats -
i am hoping its not the case, the english is being translated to french, you here the english momentarily, then the french translater steps in at a different volume level.
Then the 2 voices are in the same audio stream, and you can't simply disable one of them.
/Mats
Removing unwanted object from a Video file
By truth of life in forum EditingReplies: 11Last Post: 30th Mar 2012, 08:21 -
Removing audio channel from dat file
By Lextar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 25th Jul 2010, 22:08 -
removing one audio track from an avi movie file
By srckaimal in forum AudioReplies: 1Last Post: 4th Nov 2009, 19:28 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Removing Second Audio from XVID avi File
By mdesai in forum AudioReplies: 2Last Post: 25th May 2007, 09:51
