I WAS TRYING TO BURN MY FIRST DVD WITH DVD FLICK EVERYTHING WAS FINE UNTIL I WANTED TO BURN THE DVD, I NEED 9.78 GB FREE SPACE IN C:, WHICH I DON'T HAVE, WHAT HAPPENS IF I PRESS CONTINUE, WILL MY C: DELETE?, WILL THE QUALITY OF THE DVD BE COMPROMISED? IF SO HOW MUCH?, IS THERE ANY WAY I CAN BURN DIRECTLY TO DVD, WITHOUT GOING THROUGH C:, AND AVOID THE WHOLE ISSUE?, SINCE I DON'T THINK HOW I CAN FREE 2GB, TO ALLOW THE BURN. :?
It should error out and not do the burn. If you have another hard drive, I suggest going into the settings and pointing to the other hard drive. Otherwise, you are stuck with making space on the C: drive.
Believing yourself to be secure only takes one cracker to dispel your belief. -
all CAPS is considered shouting
DVD flick is an author convert program
assuming the DVD file is completed and on your HD drive,
use ImgBurn to do the burning, choose 'buld' from the options
and do not choose 'create image' / 'create iso'
DO choose the 32k pad option,
imgburn will burn the disc without creating an image first.
if you are starting from scratch and have not yet created the DVD files
then NO, there is NO other option than space, there HAS to be enough space on at least '1' drive where the DVD file folder can be created
you don't have to make 'disc image / iso ' files, but you do have to, have enough space for the complete DVD folders & files -
Thank you all for your advise, notice no more capitals
. I did figure out how to do it I don't know the terms but it is as you said, the image and a whole lot more was saved to HD, therefore I had no more space specially since I got excited with this whole downloading and I had several movies saved.
Great that you could help specially since I am quite out of this whole computer thing, now I know where to get answers, and fast too.
thxs -
Try running ccleaner and doing a little spring cleaning on your PC. You can likely free up quite a bit of space. Such as opening Add/Remove Progams and uninstalling all of the apps you've installed and never used.
Google is your Friend
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 07:47 -
How much free space needed for a defrag
By Rudyard in forum ComputerReplies: 5Last Post: 17th Apr 2008, 16:52 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 16:21 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55 -
Capture stop because no free space->corrupt avi
By RH+ in forum Capturing and VCRReplies: 3Last Post: 30th May 2007, 10:01
