    Mar 2008
    Italy
    hi
    i have a little problem with bluray's subs
    because i extract subs into m2ts with tsremux or xport (nothing difference)
    and i have a .sup files, i want put these subs into my mkv, and i must convert .sup file in .sub/idx
    i try with subtitlecreator, but the program crash...
    i go to Tools - manipulate SUP or Vobsub file - Open Sub - File type - SUP files
    i load the .sup files but the program load without a motivation
    the mouse cursor loading for 1,2 mins
    when finish loading, i save the idx/sub but i have a 2kb files (idx/sub) and the .sup is 10mb...
    why?
    can u help me?
    thank u
    edit: if i use sub2vobsub i have idx file 1kb, sub file 0kb
    E:\>sup2vobsub -create 00000.track_4608
    sup-file: 00000.track_4608.sup
    sub-file: 00000.track_4608.sub
    idx-file: 00000.track_4608.idx
    Sub 1
    PTS: 00:21:58:730
    Packet size: 936
    Data packet size: 0
    Parse control sequence:
    (ptr=0) Date: a8 3
    (ptr=2) Next: 0
    (ptr=4) Cmnd 0: force diaplaying
    (ptr=5) Cmnd 1: start date
    (ptr=6) Cmnd 0: force diaplaying
    (ptr=7) Cmnd 1: start date
    (ptr=8) Cmnd 0: force diaplaying
    (ptr=9) Cmnd 0: force diaplaying
    (ptr=10) Cmnd 2: stop date
    (ptr=11) Cmnd 3e:Unknown command
    (ptr=12) Cmnd 3: palette: 1 9 5 0
    (ptr=15) Cmnd 47:Unknown command
    (ptr=16) Cmnd 14:Unknown command
    (ptr=17) Cmnd 3d:Unknown command
    (ptr=18) Cmnd 55:Unknown command
    (ptr=19) Cmnd 9b:Unknown command
    (ptr=20) Cmnd 14:Unknown command
    (ptr=21) Cmnd 3d:Unknown command
    (ptr=22) Cmnd 53:Unknown command
    (ptr=23) Cmnd 50:Unknown command
    (ptr=24) Cmnd 17:Unknown command
    (ptr=25) Cmnd 0: force diaplaying
    (ptr=26) Cmnd a:Unknown command
    (ptr=27) Cmnd 1: start date
    (ptr=28) Cmnd 0: force diaplaying
    (ptr=29) Cmnd 2: stop date
    (ptr=30) Cmnd 3e:Unknown command
    (ptr=31) Cmnd 3: palette: 1 9 0 3
    (ptr=34) Cmnd 4: alpha channel: 0 0 8 7
    (ptr=37) Cmnd 50:Unknown command
    (ptr=38) Cmnd 47:Unknown command
    (ptr=39) Cmnd 14:Unknown command
    (ptr=40) Cmnd 3d:Unknown command
    (ptr=41) Cmnd 53:Unknown command
    (ptr=42) Cmnd 50:Unknown command
    (ptr=43) Cmnd 0: force diaplaying
    (ptr=44) Cmnd 0: force diaplaying
    (ptr=45) Cmnd 0: force diaplaying
    (ptr=46) Cmnd 0: force diaplaying
    (ptr=47) Cmnd 14:Unknown command
    (ptr=48) Cmnd 0: force diaplaying
    (ptr=49) Cmnd 9d:Unknown command
    (ptr=50) Cmnd 0: force diaplaying
    (ptr=51) Cmnd 1: start date
    (ptr=52) Cmnd 1: start date
    (ptr=53) Cmnd da:Unknown command
    (ptr=54) Cmnd 80:Unknown command
    (ptr=55) Cmnd 80:Unknown command
    (ptr=56) Cmnd ff: end
    Duration: 5.490 s
    Writing PES for vobsub:
    Remaining bytes: 936
    PES packet: 1
    Header size: 29
    Writing 936 bytes
    Padding 1083 bytes
  2. Member manusse's Avatar
    Jun 2006
    France
    Hi,
    Could you please put your SUP file to a file sharing site and post the link in this forum and I'll have a look.
    Cheers
    Manusse
  3. Member manusse's Avatar
    Jun 2006
    France
    OK, I had a look.
    SUP files can be of 3 types: SD types (PAL or NTSC), Blu-Ray types and HD-DVD types. Most of the tools that open SUP files only accept SD types. SubtitleCreator can open HD-DVD SUP files but not Blu-Ray SUP files. This is your problem as your SUP file is a Blu-Ray SUP file.
    VobSub format (sub/idx) is a SD format. The only way to convert a HD-DVD subtitle file to VobSub is using SubtitleCreator. It will downsample it to SD resolution and decrease its number of colors to 4 and allow to export it as sub/idx. However it can't currently open Blu-Ray Sup files.
    Cheers
    Manusse
    Mar 2008
    Italy
    so i wait a new tool that convert the sup bluray in dix and sub because there aren't a way at the moment ?
    thank u for the help
    Dec 2008
    Switzerland
    Hi,
    I'm having the same problem.
    The .sup file extracted from Blue-Ray Disk can't be converted to .idx/.sub using Subtitle Creator.
    Is there any other program I could use to convert .sup to .idx/.sub?
