hi
i am converting mkv files to dts however the get converted to ac3, iam doing this by favc. how do i maintain the dts track on dvd
I don't think favc has the option to retain dts.
You would have do it manually. I don't think there are any 1-click wonders that will do this for you.
One way might look like this: extract the streams with mkvextractgui, re-encode the video stream into a DVD compliant video (frameserve with avisynth into an mpeg encoder like cce or hcenc), import your assets into dvdlab-pro => author disc
It would be much easier to by the DVD -
thanks. i do this for experimental purposes.Originally Posted by poisondeathray
OK i converted video to m2v and now its time to multiplex that dts track with m2v. what i notice is that video is 1hr 45min where as the dts track is 1hr 47 min long.
there is a 2 min gap between audio and video. while converting audio i converted to pal.
Convert BD ISO to MKV and maintain overlays?
By netmask56 in forum Video ConversionReplies: 2Last Post: 12th Feb 2012, 05:00 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Mkv to dvd with dts
By miteshpmb in forum Video ConversionReplies: 2Last Post: 7th Jun 2010, 06:56 -
How to maintain color in mkv conversion?
By vato76 in forum Video ConversionReplies: 10Last Post: 15th Apr 2010, 11:53 -
DVD to MKV while keeping DTS and AC3??
By SilverBlade in forum DVD RippingReplies: 1Last Post: 13th Mar 2008, 15:52
