down to it
Im editing a wedding video with adobe premier 6
fantastic program to use very flexible
and i have some audio tracks that i need to use that have wind noise on them
I can cut some out but most has speech or some other audio that i need on it
does any one know a way of filtering out these wind noises ( not that kind of wind?)
I've found the noise filter in Audacity very good for this kind of thing.
Get the latest 1.3 beta version.
http://audacityteam.org/wiki/index.php?title=Noise_Removal
You will have to demux the sound, convert to wave and after cleaning in Audacity convert back to whatever format (MP3-- Audacity can handle that, AC3 use Aften, ffmpeg) and remux with the video.
If you use aggressive setting you can get weird effects, so play with the parameters and test brief passages, (just click "undo" after) before committing to a setting.
How to remove audio noise?
By Leo48 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2013, 16:09 -
Would like to remove or at least reduce wind sound from M2TS video
By kmw in forum AudioReplies: 5Last Post: 11th Nov 2010, 20:06 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 21:50 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 12:47 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 03:09
