I'm looking for a program that will transfer the content of my DV tape to the computer in as many files as there clips or scenes on the tape, and that will call each clip or scene by the date on which it was taken. Premiere Elements does not do it. ULead does not do it. Exsate DV Capture does do it, but my anti-spyware program warned me that Exsate by trying to log keys. WinDV also does what I want, but does not seem to give me any choice as to where on my computer I will save the files. Any suggestions? Thank you.
Results 1 to 11 of 11
Thanks, Johnny, I'll wander over and take a good look since it's free for personal use. Just a thought, 2-sec quick glance (literally) and "(Save $50 before April 2007)" probably needs updating on http://www.enosoft.net/products/enodvproc/dvproc_overview.htm
I downloaded WinDV at http://windv.mourek.cz/.
The anti-spyware I use is Spyware Doctor, but the key logging was detected by Threatfire (a companion program of SD).
Thanks. -
That's extremely surprising. WinDV has been around for a long time, used and trusted by many many people with no ill reports.Originally Posted by kapital
I strongly suspect it's a false notification from your Threatfire program. Still, you will want piece of mind which is fair enough - search / post in a security forum for confirmation.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I just downloaded it and did a binary file compare of the zip file with my previously downloaded version - and they're identical.
My version doesn't suffer from that and I use the latest and greatest Trend 2008 anti-virus and anti-spyware.
I'm in the corporate IT game and we had never used your "anti-" programs. I suggest you swap to some more mainline ones. Pay for Trend, you won't regret it.
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 17:21 -
Posting dates and thread dates
By stiltman in forum FeedbackReplies: 9Last Post: 21st Mar 2010, 17:18 -
How to get separate VOB files?
By rmdeboer82 in forum Authoring (DVD)Replies: 14Last Post: 18th Aug 2008, 11:37 -
43 Chapters to 11 Separate Files
By GrayStrickland in forum EditingReplies: 2Last Post: 19th May 2008, 19:15 -
Batch joining into separate files
By Bratac in forum EditingReplies: 0Last Post: 20th Aug 2007, 08:02
