Hello I have a video (dv format) editted in Adobe premier pro2 ready to be exported into a dvd. I want to know what will be the quickes one (without loosing quality)
1) export it as dvd and the use TMPGEnc DVD Author 3 or nero vision to convert the video and then burn it into a dvd.
2) Export it a dvd (mpeg2) and then write it on a dvd
3) use the export to dvd from premier itself
What will be my expected time to get my videos into a dvd. My system is pentium dualcore, 512 ddr ram, sata hdd, gefore mx 5200 graphic card.
For my last project, i exported into avi and then used TDA to create the dvd, it takes way too long, so i imported my video into Ulead vs11 and then use the export to dvd option, it takes lesser time but i'm having the pixelate (i dodnt know the exact term but if i did it using premier i would chose deinterlace and the problem would be fixed) i dont know how to fix that in ulead vs11.
Results 1 to 1 of 1
video gets shortened under dvd --> mp4 conversion
By gherardo in forum Video ConversionReplies: 7Last Post: 16th Dec 2010, 17:09 -
MPEG to DVD VIDEO-TS conversion
By efiste2 in forum Video ConversionReplies: 4Last Post: 7th Jun 2009, 16:08 -
.MOI to dvd conversion? help with Panasonic video please
By monkeypack in forum Video ConversionReplies: 7Last Post: 15th Aug 2008, 15:29 -
Video CD to DVD-video conversion
By mingul in forum Video ConversionReplies: 3Last Post: 24th Jan 2008, 03:12 -
Dvd to Video conversion
By chanel in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 09:22
