Please help!
I am converting movie from PAL to NTSC using Adobe Premiere Pro. On some strange reason the soundtrack breaks on the half of movie after Importing the AVI file. Can somebody tell me what is the problem and how should I solve it?
Thanks and sorry for my poor English!
You can try export the audio to wav using virtualdub(file->save as wav) and then use it as source audio in Premiere.
If it wont work give us more information about your source avi, like what is the audio codec? Identify propertiers with gspot. -
to: Baldrick
Your advise is working! Thank You very much! I have solved the problem
Does Anybody Need a Soundtrack or Score?
By TheIcarusDescent in forum AudioReplies: 59Last Post: 21st Jun 2011, 01:05 -
How can i change soundtrack ?
By forcedv in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2009, 09:48 -
mkv -> m4v with AC3 soundtrack problem
By jamesmac in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2008, 16:54 -
EAC3 soundtrack
By shun in forum AudioReplies: 0Last Post: 23rd Feb 2008, 07:35 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
