How is this done can't find anything under search, i should be easy to convert .avi's and other formats to play on this and others like it.
Results 1 to 15 of 15
Here are the specs:
System
Main Chip Rockchip R2608A
Capacity 2GB/4GB/8GB
Expansion Slot MiniSD Slot (512mb - 4GB)
Display
Screen Type 2.8" QVGA Touch Screen - 262K Colors
Resolution 320x240 4:3 Aspect ratio
Languages English, Traditional Chinese, Simplified Chinese, Japanese, French, German, Italian, Spanish and more
Audio Playback
Formats MP3, WMA, WMA/VBR, APE, FLAC
Frequency Response 20HZ~20KHZ
Equalizer BBE, Customizable EQ and 7 Preset EQ
Video Playback
Formats AVI (Xvid), FLV
MAX FPS 24/FPS
Recording
Audio Format WAV
Record Mode Voice recording via built in Microphone and FM radio recording
Playtime
Battery 1800mAh built in rechargeable Li-On battery
Audio 40hrs
Video 8hrs
Other Features
FM Frequency reception 76MHz ~ 108MHz - manual and autoscan - Save upto 10 favorite stations
Picture JPG, BMP, GIF
Text Multi-line text display (TXT)
Other Built in Speaker, Firmware Upgradable, Resume play for Audio, Video and Ebook
Included Accessories Wall Charger, Headphones, USB Cable, English Manual
Dimensions and Weight 85 x 50 x 11.5 mm
Interface
USB USB 2.0 High Speed via headphone jack
Headphones 3.5mm headphone output
Really i don't understand how it works i see all the files and folders so i don't know how, i thought it would be a simple drop and drag..in the right format.
thanks -
Not the same as the iPod Touch then. No H.264/AAC, no M4A. Only the look has been copied.Originally Posted by sknox
so where is a link to view/buy this thing?
who makes it?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Here is a sample avi that came with it, i don't know if i can post a small avi from the device, i mean there has got to convert it
Basically, the unit expects "generic" mp4 which ffmpegX and MPEG Streamclip can do quite easily. You'll have to play around a bit but it should just take some time until you get it right.
I forgot that under the movie title it say "Divx"
Make a difference? -
XviD, DivX - they're similar. Just create a "standard" mp4 at 320x240 (or shorter height if the video might be wide-screen) and use mp3 for the audio. Watch out for too high a bitrate; might want to try 64kb audio while you play with the video settings. Once you get a video to transfer and play, then use the same video settings and increase the audio to 96, 128 and 160kb. See where it won't work anymore and then you'll know what it can and can't do.
I like the built-in speaker; wish my iPod had that. I hate using earbuds or headphones. -
Thanks rumplestiltskin
But could you explain in a bit more detail? -
I must be missing something, i have Handbreak, ffmpegX and MPEG Streamclip.
Using the Quickstart scripts instructions with handbreak
I still can't get it to play, i get i want to put my Penn & Teller collection (yes they belong to me bought off eBay)Quickest
First, double click on the HandBrake icon to launch the application.
A window will pop up, with a sheet in front of it. The sheet will ask you select a source. If you've already got the DVD ripped to your hard drive, navigate to the VIDEO_TS folder and double-click it. If you've put a DVD into your computer, choose it from the sidebar -- but know that this is not recommended. HandBrake simply cannot break advanced copy protection, not the way a dedicated DVD cracker like MacTheRipper will.
At this point you should be looking at the main window.
Now wait a few seconds while HandBrake scans the DVD.
When the scan's done, you'll see the Source information about chapters and titles is filled in.
By default, HandBrake will auto-select the longest title from your DVD. This is, most likely, the full movie -- the title you want.
Click the start button in the toolbar.
Sit back, relax, give your hand a break, and -- with a tropical cocktail within arm's reach -- wait for your movie to encode.
When it's done, you'll find it on your Desktop.
Please help me , i should know this but i need help.
Thanks -
rumplestiltskin
I went to handbrake's forum, one person told me this
Moving to devices... Handbrake will not help you with your AVI sources.
You are probably just going to have to do a lot of experimenting; I doubt anyone on the forums here has one of these.
another person said
-----------------------------------------------------------------------------------------------------------I'd try ffmpeg video (~500 kbps) and MP3 audio (128 kbps) in an AVI container. Resize video to 320 x X (depending on source aspect ratio) and you may have to drop framerate down to 20 fps.
Other than that, trial and error is probably your best option I'm afraid.
I know it can't be that difficult to get the right way to do this.
I have been able to xfer music and pics but not video
One more note the avi's that came on this device, when played with QT i get one of those darn windows telling me im missing something i get no sound, i do when i run it thru MPEG Streamclip.
Im confused on what to do!!!
HELP me rumplestiltskin
sknoxx -
Software you will need
MPEG Streamclip
ffmpegX
1. Open video file in MPEG Streamclip and export the audio as mp2.
2. Open video file in ffmpegX and choose xvid for video format.
Under audio tab uncheck encode audio.
now choose the ecoded audio file you created with MPEG Streamclip
this has been working for me.
help with iTouch (1)
By rotuts in forum MacReplies: 4Last Post: 23rd Aug 2011, 09:39 -
FFMPEG and Itouch 4g
By barrios35 in forum Video ConversionReplies: 2Last Post: 8th Jan 2011, 17:20 -
Best Conversion Format for all USE Xbox360, PS3, iTouch, WDTVLive
By eruiz@lgwonline.com in forum Video Streaming DownloadingReplies: 4Last Post: 9th Feb 2010, 19:31 -
ffmpeg for iphone/ itouch
By invivo in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2008, 02:20 -
Ipod Itouch Question
By ultraman36 in forum Portable VideoReplies: 7Last Post: 19th Jul 2008, 08:08
