I live in the U.S and have comcast as a cable provider. Will I still be able to use my analog pc tv tuner in 2009? Also, is there a better solution coming to the market? Thanks!!!
Results 1 to 12 of 12
CATV will continue using Analog Signals but if and when they do drop Analog the Digital Set Top Box will still put out Channel 3 and Composite NTSC video for the foreseeable future.
Originally Posted by Gplracer
- more letterbox since the main channel will now be 16:9
- more four side black bars for SD source until the local stations get on the ball
- fewer cable analog channels as they expand their digital line up. Local channels will remain available in analog for years.
New tuners are coming. ATSC tuners are for over the air and do nothing for cable. QAM tuners will tune unencrypted cable channels including local SD and HD. The FCC has required that "must carry" local stations that offer HD be carried in unencrypted HD by cable systems.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If you have cable you won't have to make any changes. Cable has to carry analog far into the future.
Not to mention you would have heard from Comcast by now.... -
Originally Posted by handyguy
PS Who says Comcast's gonna let you know? -
Originally Posted by olyteddy
Most cable companies have 750MHz or more bandwidth so will continue to offer analog service. Each analog channel uses the same bandwidth (6MHz) as 8-10 SD MPeg2 or 2 HD MPeg2 subchannels.Recommends: Kiva.org - Loans that change lives.
Everyone says that cable has to do this and has to do that but I expect them to do exactly what they did with these channels when February 2009 rolls around. I don't see the government offering us a coupon to get a QAM tuner or replace our analog TVs. -
My cable TV company has been running ads making reference to all the misleading ads being run on the rebroadcast network channels such as "Bought a new TV or Digital Converter Box lately?"
These cable ads make it very clear for their customers:
1) You will need NO special equipment after the cut-off date for analog over the air TV;
2) If your TV works now with Cable, it will continue to work after the cut-off date; and
3) Isn't Cable TV Great!
Cass Cable TV -
Here's a place for feb 2009 answers in the US
http://www.dtv.gov/consumercorner.html -
Originally Posted by bendixG15
I say these so-called public service announcements are poorly made and even intentionally misleading. They should start out with "if you DO NOT watch TV off an antenna (everyone knows what the hell that is), then please ignore this message! Hell, last night on TBN, scrolling across the bottom of the movie (The Robe) was a message that my VCR and such would not work after Feb 19, 2009!
These FCC required messages should be stopped! -
Originally Posted by DarrellS
So far I've seen in the stores.
Fry's - Channel Master (has S-Video)
Best Buy - Insigna
Walmart - RCA (Funai), Magnavox
All are very basic intended for analog NTSC TV sets. The Channel Master at least had S-Video. The RCA had something called an advanced antenna port plus a standard F connector.
PS: None of these do anything with cable. They require an antenna.
With the gov't issuing $40 coupons, expect every flim flam company to be going for the gov't gold and many households will be rushing to buy tuners that will never be used. If you need one read the reviews to get a good tuner. Most of these will go unused directly to landfills thanks to the Congress' rebate program. Your tax dollars at work? The few people that need them will probably need external help to get them properly installed and programmed. Learn this stuff so you can help the non-cable elderly in your neighborhood keep their TV reception.
List of flim flam (gov't rebate) ATSC to SD analog tuners so far can be had here.
https://www.ntiadtv.gov/cecb_list.cfmRecommends: Kiva.org - Loans that change lives.
Need advice, looking for a USB Tuner/Capture Device that will work in OS X
By jrru2 in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 19:06 -
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
Best ever 2009 Camcorders ever
By Fary4u in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 22nd Jan 2010, 13:25 -
Can Nvidia Tuner box be modded to work w/o card?
By perceptionist in forum ComputerReplies: 1Last Post: 6th Nov 2009, 00:48 -
The Stepfather (2009)
By stiltman in forum Off topicReplies: 4Last Post: 19th Oct 2009, 00:20
