Is it possible to crop the original MPEG2 file without reencoding?
B.R.Vignesh
http://www.youtube.com/brvignesh -
Yep, if you mean crop like cut. Use mpg2cut2, videoredo, mpeg-vcr, tmpgenc mpeg editor...or see our tools list under Video Editors(mpg,dvd).
No, if you mean crop like remove a part in the video frame.
edit: And moving you to our editing forum. -
If by "crop" you mean cutting away a portion of the frame, like removing black letterbox bars, no. If you mean removing unwanted segments (usually called trimming around here), like cutting out commercials, yes.
is it possible to crop using videoredo?
B.R.Vignesh
yes, removing black letterboxes
B.R.Vignesh
It requires reconverting and no videoredo doesn't support it.
You can use a video mpeg2 converter like tmpgenc plus, tmpgenc xpress or free solutions like avisynth together with a hcenc to crop the black borders.
autogk wrong file size and cropping
By codemaster in forum DVD RippingReplies: 5Last Post: 5th Dec 2010, 08:09 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Cropping in Vegas Pro 8 - I crop the video, but output file still has black
By Mysteriouskk in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 11:24 -
Looking For A Cropping/Splitting/Converting Tool that supports MPEG2
By LordOfTheStrings in forum EditingReplies: 21Last Post: 12th Nov 2007, 12:09 -
HQ MPEG2 Cropping
By KnightHeart in forum Video ConversionReplies: 3Last Post: 12th Jul 2007, 16:16
