  1. Member Shotobits's Avatar
    Sep 2005
    Englang UK.
    hi, I got this error when installing K-lite mega codec pack, version 3.8.0.0
    Error creating registry key HKey classes_roor\3gp regcreatkeyEX failed;code 5 access is denied. is there a way I can get this to work? and why am I getting this error, I have a allot of still camera video clips I want to use in vegas 7, I've been told if I download the K-lite codec pack it has the all the necessory codec's for the video clips to work in vegas your help is appreciated
    The more you know the more you know that you don't know
    Apr 2004
    Miskatonic U
    Personal opinion : codec packs are just like asking for trouble. They install a lot of stuff you do not need, without giving you any control over what they do. You get mixed versions, conflicting settings, and very limited uninstall options. They take a very scatter gun approach to what is usually a very simple and straight-forward problem. Finally, they often do not uninstall nicely, leaving you with a hell of a mess. When something does go wrong (and it often does with codec packs), trouble shooting is almost impossible. Worst case, video and audio playback can be irrevocable corrupted, and only a fresh install of windows will fix it.
    Use g-spot or media info or video inspector to determine what codecs you need, and install only those codecs.
    Read my blog here.
  3. Member Shotobits's Avatar
    Sep 2005
    Englang UK.
    Thanks for the prompt reply, I think I'll follow your advice I've had this problem with codec packs before thanks for your help
    Apr 2004
    Miskatonic U
    If you need help identifying the codec you need, post a g-spot screenshot and someone will help you get it going.
    Read my blog here.
  5. Member Shotobits's Avatar
    Sep 2005
    Englang UK.
    thanks
