For some reason, Vista enterprise edition has some problems playing avi/mpg on the WMP 11. It says it cannot find the coding. I had no problem with XP version running WMP 11 (same music files). I tried doing a search but didnt find anything on this topic. What's the deal on this?
Results 1 to 12 of 12
Vista Enterprise is essentially Vista Business with a handful of extra features. Both lack some multimedia features such as Media Center. HD MovieMaker and DVD Authoring. This *may* mean that some codecs available out-of-the-box with Home Premium and Ultimate are not present.
In addition to Baldrick's recommendation, VLC may work for you, too.John Miller -
yep, all those mentioned above are installed. no problem in xp, now i have problems
Click on the Start menu
Right-click on Computer
Select Properties in the menu
Under System you'll see System type - e.g., 32-bit Operating System -
32 bit, i thought 64 is only AMD right now?
Anyways, what does that matter? All I know is, the same exact divx music files (avi) plays on my desktop (XP professional on WMP 11), but the same file does NOT have codec on Vista Enterprise on WMP 11) All the same codecs (divx, ffdshow, etc) installed on both units too.....So weird.... -
It matters because the 64-bit version has both 32- and 64-bit versions of WMP. 64-bit WMP can only use 64-bit codecs. But, since you have 32-bit, it's a moot point.
Have you registered the codecs on Vista? Sometimes things like codecs don't register properly during the installation process.
In Computer, go to the folder above the one where the DivX codec is installed. While pressing the shift button, right click on that folder (the one with DivX) and select Open Command Window Here. You'll see a command window open and you will be in the folder containing the DivX codec. If the name of the codec if fred.dll, type:
regsvr32 fred.dll
If regsvr32 isn't recognized, type:
%systemroot%\system32\regsvr32 fred.dll
Vista wmp -> swf's
By mikeo1313 in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2009, 14:40 -
Win Vista 64 - Enterprise
By kenmo in forum ComputerReplies: 1Last Post: 23rd Apr 2009, 10:54 -
Can't display subs with WMP & Vista Media Center
By amir77a in forum SubtitleReplies: 2Last Post: 14th Mar 2008, 18:13 -
Widescreen MPEG2 cropped to 4:3 in WMP 11 and Vista Media Center
By daemonic3 in forum Software PlayingReplies: 1Last Post: 26th Feb 2008, 00:01 -
How do I play FLAC files in WMP 11 in Vista?
By Cereal Bawks in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2007, 17:24
