I seeing a strange issue trying to rip Hitman from DVD to H.264. After I convert with handbreak, there is a scene that is repeated. After it repeats once, it keeps going on with the rest of the movie. If I watch the ripped DVD on my hard drive, it does not repeat this scene.
Any thoughts? I ran it through FixVTS and now luck there.
For the love of God, use hub/core labels on your Recordable Discs!
First thing that comes to mind is a angle issue. Does the IFO report one section of the movie having multiple angles for slightly different story lines? This maybe addressed with menu selections so you may never know its there.
Ok in the main ifo for the movie you will get this information..
I don't have any multi angle movies on hand this is a simple straight forward one. can you put you information in a reply for us to look at please..
Menu attributes:
Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (4:3) (not specified perm.display)
Title Set (Movie) attributes:
Audio 1: Not Specified (Dolby AC-3) 2ch 48Kbps DRC (ID: 0x80)
PGC_1 (program chain): [Title(TTN): 1] [01:04:34.04 / 30 fps] (Programs: 19) (Cells: 19) (uses VOB-IDs: 1)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:04:13.28 / 30 fps [Pos: 00:04:13.28] [Frames: 7618] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
[Ch 02] [Pg 02] [Cell 02] [V/C Id: 1/ 2] : time: 00:02:45.29 / 30 fps [Pos: 00:06:59.27] [Frames: 12597] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 03] [Pg 03] [Cell 03] [V/C Id: 1/ 3] : time: 00:02:54.19 / 30 fps [Pos: 00:09:54.16] [Frames: 17836] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 04] [Pg 04] [Cell 04] [V/C Id: 1/ 4] : time: 00:04:00.28 / 30 fps [Pos: 00:13:55.14] [Frames: 25064] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 05] [Pg 05] [Cell 05] [V/C Id: 1/ 5] : time: 00:03:44.14 / 30 fps [Pos: 00:17:39.28] [Frames: 31798] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 06] [Pg 06] [Cell 06] [V/C Id: 1/ 6] : time: 00:03:50.03 / 30 fps [Pos: 00:21:30.01] [Frames: 38701] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 07] [Pg 07] [Cell 07] [V/C Id: 1/ 7] : time: 00:02:51.18 / 30 fps [Pos: 00:24:21.19] [Frames: 43849] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 08] [Pg 08] [Cell 08] [V/C Id: 1/ 8] : time: 00:03:54.26 / 30 fps [Pos: 00:28:16.15] [Frames: 50895] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 09] [Pg 09] [Cell 09] [V/C Id: 1/ 9] : time: 00:02:49.13 / 30 fps [Pos: 00:31:05.28] [Frames: 55978] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 10] [Pg 10] [Cell 10] [V/C Id: 1/10] : time: 00:03:22.11 / 30 fps [Pos: 00:34:28.09] [Frames: 62049] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 11] [Pg 11] [Cell 11] [V/C Id: 1/11] : time: 00:04:10.01 / 30 fps [Pos: 00:38:38.10] [Frames: 69550] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 12] [Pg 12] [Cell 12] [V/C Id: 1/12] : time: 00:03:57.14 / 30 fps [Pos: 00:42:35.24] [Frames: 76674] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 13] [Pg 13] [Cell 13] [V/C Id: 1/13] : time: 00:02:52.27 / 30 fps [Pos: 00:45:28.21] [Frames: 81861] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 14] [Pg 14] [Cell 14] [V/C Id: 1/14] : time: 00:02:23.00 / 30 fps [Pos: 00:47:51.21] [Frames: 86151] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 15] [Pg 15] [Cell 15] [V/C Id: 1/15] : time: 00:04:19.04 / 30 fps [Pos: 00:52:10.25] [Frames: 93925] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 16] [Pg 16] [Cell 16] [V/C Id: 1/16] : time: 00:03:21.28 / 30 fps [Pos: 00:55:32.23] [Frames: 99983] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 17] [Pg 17] [Cell 17] [V/C Id: 1/17] : time: 00:03:21.15 / 30 fps [Pos: 00:58:54.08] [Frames: 106028] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 18] [Pg 18] [Cell 18] [V/C Id: 1/18] : time: 00:05:36.08 / 30 fps [Pos: 01:04:30.16] [Frames: 116116] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 19] [Pg 19] [Cell 19] [V/C Id: 1/19] : time: 00:00:03.18 / 30 fps [Pos: 01:04:34.04] [Frames: 116224] SP/ILVU/DISC/SA:[yes/ no/ no/ no] -
This is what I see when I open the 1st VTS .IFO file:
VTS overview:
Menu attributes:
Video: MPEG-2 720x480 (NTSC) (NTSC 525/60) (16:9) (letterboxed)
Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC normal (ID: 0x80)
Audio 2: English (DTS ) 6ch 48Kbps DRC normal (ID: 0x89)
SubPicture 1: English (2-bit rle ) (ID: 0x20,0x21)
PGC_1 (program chain): [Title(TTN): 1] [01:34:13.15 / 30 fps] (Programs: 25) (Cells: 35) (uses VOB-IDs: 1,2,3)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:00:23.20 / 30 fps [Pos: 00:00:23.20] [Frames: 710] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
[Cell 02] [V/C Id: 1/ 2] : time: 00:02:33.08 / 30 fps [Pos: 00:02:56.28] [Frames: 5308] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 02] [Pg 02] [Cell 03] [V/C Id: 1/ 3] : time: 00:02:06.28 / 30 fps [Pos: 00:05:03.26] [Frames: 9116] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 03] [Pg 03] [Cell 04] [V/C Id: 1/ 4] : time: 00:03:10.19 / 30 fps [Pos: 00:08:14.15] [Frames: 14835] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 04] [Pg 04] [Cell 05] [V/C Id: 1/ 5] : time: 00:02:11.01 / 30 fps [Pos: 00:10:25.16] [Frames: 18766] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 06] [V/C Id: 1/ 6] : time: 00:03:07.29 / 30 fps [Pos: 00:13:33.15] [Frames: 24405] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 05] [Pg 05] [Cell 07] [V/C Id: 1/ 7] : time: 00:04:10.01 / 30 fps [Pos: 00:17:43.16] [Frames: 31906] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 06] [Pg 06] [Cell 08] [V/C Id: 1/ 8] : time: 00:00:54.09 / 30 fps [Pos: 00:18:37.25] [Frames: 33535] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 09] [V/C Id: 1/ 9] : time: 00:05:36.20 / 30 fps [Pos: 00:24:14.15] [Frames: 43635] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 07] [Pg 07] [Cell 10] [V/C Id: 1/10] : time: 00:02:08.25 / 30 fps [Pos: 00:26:23.10] [Frames: 47500] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 08] [Pg 08] [Cell 11] [V/C Id: 1/11] : time: 00:00:38.11 / 30 fps [Pos: 00:27:01.21] [Frames: 48651] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 12] [V/C Id: 1/12] : time: 00:03:16.15 / 30 fps [Pos: 00:30:18.06] [Frames: 54546] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 09] [Pg 09] [Cell 13] [V/C Id: 1/13] : time: 00:04:52.00 / 30 fps [Pos: 00:35:10.06] [Frames: 63306] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 14] [V/C Id: 1/14] : time: 00:00:31.29 / 30 fps [Pos: 00:35:42.05] [Frames: 64265] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 10] [Pg 10] [Cell 15] [V/C Id: 1/15] : time: 00:07:44.01 / 30 fps [Pos: 00:43:26.06] [Frames: 78186] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 11] [Pg 11] [Cell 16] [V/C Id: 1/16] : time: 00:03:19.19 / 30 fps [Pos: 00:46:45.25] [Frames: 84175] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 12] [Pg 12] [Cell 17] [V/C Id: 1/17] : time: 00:02:05.20 / 30 fps [Pos: 00:48:51.15] [Frames: 87945] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 13] [Pg 13] [Cell 18] [V/C Id: 1/18] : time: 00:01:51.26 / 30 fps [Pos: 00:50:43.11] [Frames: 91301] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 19] [V/C Id: 2/ 1] : time: 00:00:16.24 / 30 fps [Pos: 00:51:00.05] [Frames: 91805] SP/ILVU/DISC/SA:[yes/ no/yes/ no]
[Ch 14] [Pg 14] [Cell 20] [V/C Id: 2/ 2] : time: 00:03:45.15 / 30 fps [Pos: 00:54:45.20] [Frames: 98570] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 15] [Pg 15] [Cell 21] [V/C Id: 2/ 3] : time: 00:04:10.21 / 30 fps [Pos: 00:58:56.11] [Frames: 106091] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 16] [Pg 16] [Cell 22] [V/C Id: 2/ 4] : time: 00:00:34.10 / 30 fps [Pos: 00:59:30.21] [Frames: 107121] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 23] [V/C Id: 2/ 5] : time: 00:04:30.04 / 30 fps [Pos: 01:04:00.25] [Frames: 115225] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 17] [Pg 17] [Cell 24] [V/C Id: 2/ 6] : time: 00:02:21.10 / 30 fps [Pos: 01:06:22.05] [Frames: 119465] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 18] [Pg 18] [Cell 25] [V/C Id: 2/ 7] : time: 00:02:03.16 / 30 fps [Pos: 01:08:25.21] [Frames: 123171] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 26] [V/C Id: 2/ 8] : time: 00:01:11.24 / 30 fps [Pos: 01:09:37.15] [Frames: 125325] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 19] [Pg 19] [Cell 27] [V/C Id: 2/ 9] : time: 00:03:11.01 / 30 fps [Pos: 01:12:48.16] [Frames: 131056] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 20] [Pg 20] [Cell 28] [V/C Id: 2/10] : time: 00:02:39.25 / 30 fps [Pos: 01:15:28.11] [Frames: 135851] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 21] [Pg 21] [Cell 29] [V/C Id: 2/11] : time: 00:01:09.05 / 30 fps [Pos: 01:16:37.16] [Frames: 137926] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 30] [V/C Id: 2/12] : time: 00:07:50.14 / 30 fps [Pos: 01:24:28.00] [Frames: 152040] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 22] [Pg 22] [Cell 31] [V/C Id: 2/13] : time: 00:03:16.20 / 30 fps [Pos: 01:27:44.20] [Frames: 157940] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 23] [Pg 23] [Cell 32] [V/C Id: 2/14] : time: 00:02:34.15 / 30 fps [Pos: 01:30:19.05] [Frames: 162575] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 24] [Pg 24] [Cell 33] [V/C Id: 2/15] : time: 00:03:45.25 / 30 fps [Pos: 01:34:05.00] [Frames: 169350] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Cell 34] [V/C Id: 2/16] : time: 00:00:08.00 / 30 fps [Pos: 01:34:13.00] [Frames: 169590] SP/ILVU/DISC/SA:[yes/ no/ no/ no]
[Ch 25] [Pg 25] [Cell 35] [V/C Id: 3/ 1] Layer Br.: time: 00:00:00.15 / 30 fps [Pos: 01:34:13.15] [Frames: 169605] SP/ILVU/DISC/SA:[ no/ no/yes/ no] -
Bump.
Is there anyway I can edit this so that its just one chapter? Maybe that will fix it?For the love of God, use hub/core labels on your Recordable Discs! -
My ripped copies of The Matrix and Terminator 2 have the same problem. I've converted them to avi files using FairUseWizard and scenes repeat in each of the movies. I've tried using meGUI on the Matrix instead but it still happens, only worse. Did you ever come up with a working solution?
Repeated GUI Crashing
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 8th Mar 2010, 07:48 -
Trying to rip a scene from a DVD, questions
By Cyber Akuma in forum DVD RippingReplies: 5Last Post: 8th Jul 2009, 21:35 -
Hitman BD disc
By bimboppin in forum Blu-ray RippingReplies: 8Last Post: 30th Mar 2008, 06:43 -
cant bypass HitMan BD with AnyDVD 6.4.0.0!
By nightshade11 in forum Blu-ray RippingReplies: 4Last Post: 21st Mar 2008, 08:53 -
hitman blu ray disc?
By bimboppin in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 10:22
