I've got two video files with late audio...I've tried the MPC audio time shift thing, but it only works for the first second or so (if at all, it's hard to tell). After that, the audio slips five or so seconds behind again (disclaimer: my time estimation skills are practically nonexistant). What's the solution?
A third file is out of sync in VLC, but plays fine in MPC...am I doomed for a life of fiddling around to play it, or can that be fixed?
What kind of video/audio formats? Most times what you describe is because the audio and video files are different lengths. That causes the sync error to change as the file plays. An audio offset like MPC or VirtualDub can do only works if you need to add a delay or increase the delay to the start of the file.
Sync errors can be caused by VBR audio, bad cuts and joins, bad framerate conversions, (Like PAL<>NTSC) or corrupted audio or video, and probably a few others. If you created the files yourself, there must be something amiss with your process. And it's much easier to prevent than fix.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Feb 2010, 20:50 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Audio doesn't broadcast in WME
By versionII in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 10:40
